Activity Forums Apple Final Cut Pro Legacy Compressor Quicktime “interlaced” stays checked
  • Compressor Quicktime “interlaced” stays checked
    Posted by Brian Berdan on October 6, 2010 at 4:32 pm
    I have a Motion JPEG A Quicktime file that I’m trying to convert to ProRes. Taking a preset from Quicktime/ProRes422 and applying it to the clip, I find that in the Format Inspector/Encoder/Video settings the “Interlaced” checkbox won’t stay unchecked. I found this after running an overnight batch. I uncheck it and then hit OK and then click on settings again and it’s checked. The source is 24frame progressive. I don’t think it matters but I’m changing the size from 1080 to 720.
    I’m glad it’s only the night before our screening!
    Thanks for any help.
    Brian
    Brian Berdan
    migrant filmworker
    currently on a MacPro, using FCP 7.0.2, ProResLT from eSATA G-Raid (4 TB of incredible footage) and a now a Matrox MX02LE just to make it more complicated… love calibrating my projector though.
    Rafael Amador replied 15 years, 10 months ago 2 Members · 1 Reply
  • Rafael Amador
    October 6, 2010 at 4:37 pm
    [Brian Berdan] “The source is 24frame progressive. I don’t think it matters but I’m changing the size from 1080 to 720.”
    If you are downscaling, I think its matter a lot.
    The downscaling is been done in a field base.
    rafael
    http://www.nagavideo.com
