Activity Forums Apple Final Cut Pro Legacy Compressor Quicktime Error-50
  • Compressor Quicktime Error-50
    Posted by Matthew Cohn on September 17, 2010 at 10:16 pm
    Hello,
    I’ve read up thoroughly on the Quicktime Error-50 in Compressor and haven’t found anything that helps. I’m bringing a Quicktime file, ProRes 422, self-contained into Compressor, and with various different QT files I get this same error. Does anybody know what the cause of this might be? I do know that the start up drive only has about 3 gigs of free space on it. Could that be an issue with this particular problem? (We’re currently working on freeing up more space, but I’m just curious if that might be a cause)
    Thank you,
    Matt
    MacPro 2 x 2.66 GHz Dual-Core Intel Xeon, FCP 6.0.6, Compressor 3.0.5
    Rafael Amador replied 16 years ago 2 Members · 1 Reply
  • Rafael Amador
    September 18, 2010 at 10:36 am
    [Matt Cohn] ” I do know that the start up drive only has about 3 gigs of free space on it. Could that be an issue with this particular problem? (We’re currently working on freeing up more space, but I’m just curious if that might be a cause)”
    Probably.
    Most application require room in the System HD (Virtual Memory) to work properly. Some need to write lot of temporal files before finishing any process. There are plugins like the FC SmoothCam that needs many GBs for the files created while analyzing the footage.
    In a media HD you need at least a 10% of free space. In a System HD you may need even more.
    Rafael
    http://www.nagavideo.com
