Activity Forums Apple Final Cut Pro Legacy Compressor, QuickTime don’t support nonsquare pixels?
  • Compressor, QuickTime don’t support nonsquare pixels?
    Posted by Drew Lahat on July 27, 2009 at 5:09 am
    I have DVCProHD MOVs, rewrapped by FCP 6.0.6 from the original P2 MXF media using the regular Log and Transfer function. These have a native resolution of 960×720.
    In Quicktime Player, the inspector reports the format as “960×720 (1248×702)”. The Normal Size is 1248×702. Why that size? no idea. At least it shows the correct aspect ratio.
    I’m trying to transcode to H.264 using Compressor 3.0.5, and these show up in QT Player as “960×720 (1280×720)” – but the Normal Size is 960×720. QT Player insists treating the file like it has square pixels.
    Under Geometry, I tried to force the dimensions manually – frame size 960×720, pixel aspect 0.75 DVCProHD 720p60 16:9 – it made no difference.
    Am I expecting too much from Compressor and Quicktime?
    I’m using QT Player 7.6.2.
    Rafael Amador replied 17 years, 1 month ago 2 Members · 1 Reply
  • Rafael Amador
    July 27, 2009 at 9:12 am
    1280×720 Square pixels is the same frame than 960×720 HD pixels.
    Computers works with Square pixels, so if you want your picture properly displayed everywhere, export 1280×720 Square pixels.
    rafael
    http://www.nagavideo.com
