Activity Forums Apple Final Cut Pro Legacy Compressor problems
  • Compressor problems
    Posted by Eli Mavros on June 3, 2005 at 4:03 pm
    I was trying to make a 24p DVD last night, and followed the steps on Ken Stone’s website (exporting as FCP movie, using current settings, and then bringing it into compressor). I used the 60 minute fast encode setting in compressor, not changing any of the settings. When I brought that movie into DVDSP and tried to build and burn, I got an error “Bit Rate Too High”. I did not set the bit rate…it was a compressor preset! So why should the program output my movie with too high of a bitrate? The piece is 40 minutes right now…so it is not a short encode. I then tried just exporting from the timeline straight to compressor, forgoing the 24p DVD idea; I used the same compressor setting…and lo and behold, had the same darn problem when trying to build the DVD. Eventually, I just took the quicktime that I had exported originally and dropped it into DVDSP and let it encode it. It finally worked.
    What am I doing wrong with compressor? Why do I have to change the bitrate on a factory preset? If I do have to duplicate and change it, then what should I set the bitrate to?
    Thanks in Advance,
    Eli Mavros
    Eli Mavros
    Jerry Hofmann replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 3, 2005 at 5:15 pm
    I can’t tell you why you had the problem, but I don’t have it here doing very similar things. It sounds to me like you’ve done the right thing, so maybe a reinstall of Compressor will fix you up.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
