Activity Forums Apple Final Cut Pro Legacy COMPRESSOR PROBLEM
  • COMPRESSOR PROBLEM
    Posted by Katherine on June 29, 2005 at 3:52 pm
    I am trying to make a MPEG 2 from a DV NTSC sequence out of Final Cut Pro HD using Compressor. The MPEG has little lines going across it, as if the video is breaking up, especially when there is motion. Titles, which were created in Live Type, and/or Final Cut Pro, also have these lines when they are moving. It is as if I am seeing two fields at once when I look at a still frame. I have tried changing which field goes first in Compressor, all the options. I have also tried it in the sequence, just to see. I have tried making a tape of the cut (the tape looks OK), redigitizing it and making the MPEG of this. No luck. Any suggestions?
    Any way to at least get the titles looking OK?
    Katherine
    Katherine replied 21 years, 2 months ago 2 Members · 2 Replies
  • Chris Tompkins
    June 29, 2005 at 4:21 pm
    R U viewing it on your computer screen? Print the Disc and view it on a TV Monitor
  • Katherine
    June 29, 2005 at 7:54 pm
    Thanks.
    It looks OK on the TV screen.
    I feel a little silly now.
