Activity Forums Apple Final Cut Pro Legacy compressor problem with finished project
  • compressor problem with finished project
    Posted by Lawrence Robbin on November 5, 2008 at 4:03 pm
    I am attempting to export a finished project using the compressor. For the first time, the compressor is not working. I have dragged the mpeg 2 settings into the project (as I have done in the past) and pressed Submit. Nothing is happens – other than a window comes up confirming the name of the newly submitted project. After that, nothing. This is the first time that the compressor has not started the transcoding process. I have tried with 2 projects and each time when I press Submit, no response, i.e., no bar appears showing coding process.
    Any ideas?
    Lawrence Robbin replied 17 years, 10 months ago 2 Members · 2 Replies
  • John Fishback
    November 7, 2008 at 6:37 pm
    In the History window have you clicked the arrow to open the job? It’s probably the Today line.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Lawrence Robbin
    November 7, 2008 at 7:05 pm
    I’ll check the history window as you suggest. Numerous difficulties. Earlier today, I did an attempted export to mpeg 2 from FCP. After 3 hours of encoding, the coding suddenly quit. No evidence of the mpeg file anywhere. I could see it being built when I looked for it on Finder while the encoding was going on. But then the process stopped and the 1.? GB mpeg 2 file disappeared. Right now I’m re-rendering the video files on the FCP timelines safter I made some adjustments to the render settings. Working on a MacBookPro, there are hours of waiting to see if my various attempts have succeeded.
    LR
