Activity › Forums › Apple Final Cut Pro Legacy › compressor problem
  • compressor problem
    Posted by Tony French on September 28, 2009 at 10:52 am
    I’m trying to submit a quicktime file for process in compressor and when ever i press submit a pop up window appears with name/cluster/priority. i don’t want to create a cluster but if i press cancel i cannot submit my process. does anyone know the reason behind this. many thanks.
    Chris Borjis replied 17 years ago 5 Members · 6 Replies
  • Rafael Amador
    September 28, 2009 at 11:31 am
    No idea, but clean the “History Window” and try again.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Simon Tyszko
    September 28, 2009 at 12:20 pm
    I am just experiencing exactly the same issue. i have repaired permissions, deleted the compressor prefs, cleared the history panel yet still the submit button on the cluster popup menu remains greyed out?
    i was in the middle of a 60 hour render when the compressor controller hung (activity monitor) and trying to either restart the queue or starting a new one comes up against this issue..
    stuck!
  • Michael Gissing
    September 28, 2009 at 1:51 pm
    [tony french] “when ever i press submit a pop up window appears with name/cluster/priority”
    That is normal. It lets you name the file, set a cluster and priority. If you cancel that you are cancelling the submit.
    If you want to just name then ignore the cluster setting (which on my machine just defaults to my computer). I set priority to high because I want it to go as fast as it can.
  • Rafael Amador
  • Simon Tyszko
    September 28, 2009 at 3:58 pm
    i tried the digital rebel compressor fix, and ended up having to reinstall the whole suit, and still icompressor comes up with that second dialog box with submit greyed out!
    grrrrrrrrr
    hahahahaha
    next?
    xx
  • Chris Borjis
    September 29, 2009 at 12:04 am
    does it let you choose “this computer”
