Activity › Forums › Apple Final Cut Pro Legacy › compressor problem
  • compressor problem
    Posted by Scott B on December 6, 2006 at 4:27 pm
    The problem I’m having is actually with Compressor, but since I didn’t see a Compressor forum thought I’d try here.
    When I use Compressor to convert an FCP 5 reference movie file to any type of compressed QT file, the conversion is aborted and batch monitor says it was stopped because of “Quicktime error – 120”. I used to convert ref movies like this all the time, so I’m confused as to why I’m getting this message now.
    Thanks.
    Lee Berger replied 19 years, 10 months ago 2 Members · 1 Reply
  • Lee Berger
    December 6, 2006 at 11:36 pm
    After a quick search it seems as if error 120 is “directory not found.” After you exported the “by reference movie” did you change any directory names or move files? I would try the export with the “self contained” check box selected to get your project encoded and out the door.
    Lee Berger
    http://www.leebergermedia.com
