Activity Forums Compression Techniques compressor problem
  • compressor problem
    Posted by Trevor Fife on May 9, 2008 at 12:36 am
    anyone have problems exporting a sequence from FCP into compressor to create a progressive download file? I’ve got “fast start” selected in the inspector window but when its tested the file is only viewable by downloading the entire file first. I’ve read posts saying this was a quirk with compressor and that the only way was fix this was to export as QT from FCP sequence first, then open in compressor and proceed. I’m trying to avoid this as doing so produces a slightly subpar image comparatively. This is visible in text especially. any insight would be greatly appreciated!
    -tf
    Daniel Low replied 18 years, 4 months ago 2 Members · 1 Reply
  • Daniel Low
    May 9, 2008 at 1:42 pm
    Have a try with this:
    https://www.qtbridge.com/lillipot/lillipot.html
    Please let us know how you got on…
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
