Activity › Forums › Compression Techniques › Compressor preset export.
Posted by Scott Davis on February 16, 2007 at 7:46 pmIs there a way of saving a preset (not as a droplet) in Compressor to move to another machine?
Charles Simonson replied 19 years, 7 months ago 2 Members · 3 Replies -
Charles Simonson
February 16, 2007 at 9:09 pmYep. Save your preset and then from the Finder, go to the Go command from the top menubar and select Go to Folder… and type in /Applications/Compressor/Contents/Resources/English.lproj/
Your settings should be in that folder. -
Scott Davis
February 16, 2007 at 10:04 pmThanks Charles, Weird thing is they werent there. I did find them in my user-application support-compressor folder.
Strange
Charles Simonson
February 17, 2007 at 12:37 amYep, I would say that is weird. On my MBP at least, the settings in the directory you mentioned are all alias’ to the ones in the Compressor application package. But I would think where you found them in your user folder would be a safer way of going about getting them.
