Activity Forums Compression Techniques Compressor pre sets.
  • Compressor pre sets.
    Posted by John Mahoney on September 30, 2013 at 12:14 pm
    I have 1 hr of footage shot DVCPRO 720 60P.
    I have found that the fastest way to get an H264 of this, is to drag it into compressor. I select the preset for Apple tv, 1280X720 5Mbps progressive. It works great and is fast enough. The only problem is that it is 30P not 60. Even though in the Compressor inspector window it says frame rate is 100% of original.
    I made a copy of the pre set so i could edit it. But it wont go beyond 30Fps.
    I would like to be able to keep the 60Fps
    John Mahoney replied 12 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
