Activity Forums Apple Final Cut Pro Legacy Compressor – outputting to 16:9 MPEGs
  • Compressor – outputting to 16:9 MPEGs
    Posted by The Wickerman on September 4, 2007 at 2:09 am
    Hi all,
    I’m not very good at using Compressor and can’t seem to get the settings right. I’m trying to output a 16:9 anamorphic sequence from FCP5 into a simple MPEG1 but the resulting file is ALWAYS 4:3, even when I tell Compressor to use 16:9. Does anyone know why this is happening?
    Cheers.
    Neil Ryan replied 19 years ago 3 Members · 2 Replies
  • Uli Plank
    September 4, 2007 at 9:08 am
    AFAIK, MPEG-1 doesn’t support 16:9. You’ll need to letterbox it in FCP or use MPEG-2.
    Regards,
    Uli
  • Neil Ryan
    September 5, 2007 at 2:01 am
    Some applications will make 16:9 mpeg-1 files; Compressor is not one of those. (And even then, not all players will play a 16:9 pmeg-1 file correctly, anyway. Last time I checked, Quicktime played them correctly; Windows Media Player on PCs didn’t)
    The new version of Compressor does allow you to letterbox 16:9 into a 4:3 setting, though I found its quality very ordinary. Give it a try.I got better results letterboxing within FCP.
    Neil.
