Activity Forums Apple Final Cut Pro Legacy compressor once again
  • compressor once again
    Posted by Nuisance422 on February 15, 2007 at 3:41 pm
    thanks for the help last time guys..the audio is great..
    but i cant say the same for the video..it still kinda skips..
    it seems like the dvd player cant handle it..
    i compressed the video out of compressor using new-default mpeg_2
    is there a better compression to use for a 30 minute video? so it doesnt pixelate?
    thanks again guys,
    you guys are great
    im honored to be on COW
    Ron James replied 19 years, 7 months ago 4 Members · 3 Replies
  • David Bogie
    February 15, 2007 at 6:10 pm
    is there a better compression to use for a 30 minute video? so it doesnt pixelate?< Not tuned in to you r previous thread. What player? Set top or on your Macintosh? Exporting out of FCP using MPEG2 in Compressor is not as elegant as simply going to DVDSP with a reference movie. LEt DVDSP run the encode for you. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
  • Zack Hill
    February 15, 2007 at 8:41 pm
    bogiesan, I wondered about the idea of working with a reference movie in DVDSP, as I had read about this, but also read that compressor is a better tool than using DVDSP to compress Mpeg2. Have you tested out the two different methods? I would be really interested to know which is a more powerful and accurate tool. Thanks,
    jesus
    http://www.zeechproductions.com
  • Ron James
    February 16, 2007 at 10:06 pm
    I’m not Bogiesan, but…
    I’ve gotten great results with Compressor…AFTER realizing that the Gamma needs to be adjusted.
    At first, I was getting milky blacks, and this made artifacts much more noticeable than they should be of course (like in areas of shadow, for instance).
    I now adjust the Gamma to 1.2 and also tweak the contrast depending on the material.
    I’ve gotten great results with even a CBR of 6.1 (to ensure most DVD players will be able to handle it). I also use a VBR with a peak of 7.1. Of course, I sometimes need to adjust depending on the material.
