Activity › Forums › Apple Final Cut Pro Legacy › Compressor not working?
Posted by Chris Balogh on March 19, 2009 at 1:56 pmI do not know why, but I have used this in the past and all of a sudden it is currently not working:
on the programs bar it has a ? on the icon, when i try to use compressor with exporting it states it is not properly installed?
how do i make this run again? Help!
Rafael Amador replied 17 years, 6 months ago 4 Members · 4 Replies -
Joe Haughey
March 19, 2009 at 2:35 pmYou may have accidently deleted it… i did the same with Color a while back.. get your FCP install disks out and do a cutsom install of just Compresor, that should do it
Joe Haughey
https://www.editmule.com -
Rafael Amador
March 19, 2009 at 2:43 pmIf is not properly installed there is only one think to do: Install it properly.
Try installing the last version you had or update it through Software Update.
If the problems persists you will need un-install and reinstall again.
Try an application call “Compressor Repair” (Google).
Rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Sean Schiavolin
March 19, 2009 at 6:10 pmI’m having problems with Compressor today as well. I suspect because I accepted some updates before leaving last night. They seemed harmless. They always do! Anyway, I can open Compressor but when I select a file to encode it bogs down and eventually I have to force quit.
I guess I’ll try re-installing. any other ideas?
Rafael Amador
March 20, 2009 at 4:23 am[Sean Schiavolin] “I guess I’ll try re-installing. any other ideas?”
Run Diskwarrior.
rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
