Activity Forums Apple Final Cut Pro Legacy Compressor not showing any windows
  • Compressor not showing any windows
    Posted by Brandon Fenty on February 25, 2013 at 11:43 pm
    This was driving me nuts for almost a week and I finally found the answer, so I decided when I found the answer.
    I was running Compressor on a headless Mac Mini server. When I tried to run Compressor on it, the Mini would show the splash screen but then no windows would show. I tried everything, from clearing preferences to a complete re-install of Compressor. Turns out, the issue is the fact that I was running the system as a headless server. If you check the logs, it says that you need an OpenGL compatible display connected. I reconnected a monitor, and that’s all it took.
    I just wanted to post this in case there’s anyone else struggling with this one.
    http://www.orangeslicevideo.com
    Brandon Fenty replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
