Activity Forums Apple Final Cut Pro Legacy Compressor not recognized by FCP wont Submit.
  • Compressor not recognized by FCP wont Submit.
    Posted by Uriel Reyes on August 4, 2010 at 7:06 am
    Hey peeps;
    problem: I upgraded from suit2 to suit3 last night, now that im trying to export a sequence using “Export using Compressor”, I cant, its not even an option in the Export tab! How can I get final cut pro 7 to recognize Compressor 3.5?
    Also, i tried using the “Send to…” with compressor; it does open, however, once I drag my settings and destinations, hit submit, and name my file, the submit button is shaded. It wont let me click on it!!!
    Any tips?
    Michael Gissing replied 16 years, 1 month ago 2 Members · 1 Reply
  • Michael Gissing
    August 4, 2010 at 7:31 am
    Something is wrong with your install. I can export to Compressor from FCP 7.0.2 .
    Did you do a clean install or just update over FCS2? Also is the OS and FCS3 fully updated to latest versions?
    Meanwhile, you could export a self contained QT movie (use current settings) and then open that in Compressor.
