Activity › Forums › Compression Techniques › Compressor Not Adding Color Profile Metadata
  • Compressor Not Adding Color Profile Metadata
    Posted by Kieran Hanrahan on February 4, 2014 at 6:28 pm
    Hello,
    Thanks in advance for any replies.
    When using Compressor 3.5.3 to make a Prores422HQ from an RGB Uncompressed clip, the result clip is in Rec709 colorspace but it does not have the color profile 1-1-1 metadata added to it.
    If my source file is YUV then the output file will have the color profile metadata applied to it. I can confirm this by viewing the info in the Finder.
    This seems inconsistent to me. Am I missing a setting to force it to added the profile metadata? I have tried preserve source, Rec709, and Default for Encoder in Output Color Space menu. Right now, I use Automator to add the color profiles.
    Thanks again
    Kieran Hanrahan replied 12 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
