Activity Forums Apple Final Cut Pro Legacy Compressor Multi-task?
  • Compressor Multi-task?
    Posted by Evan Thomas phillips on July 18, 2007 at 9:06 pm
    I know that you can have multiple FCP files open at the same time, but can you put multiple sequences into compressor simultaniously as a batch? I’ve tried putting sequences in compressor, not submitting the batch, then going back to FCP to add another sequence, but I get the spinning beach ball. Is there a way to do this? Why else have a batch feature?
    J. Tad newberry replied 19 years, 2 months ago 4 Members · 4 Replies
  • Tad Newberry
    July 18, 2007 at 9:12 pm
    hmmm… it has always worked for me just as you described.
    i’ve just upgraded to FCP 6 and haven’t tried it there yet, but in 5.0.4 i would open a sequence (or select it in the ), go to “export/compressor” select my output settings for that sequence, then click right back into FCP and open or select another sequence and repeat until done. i usually do this before going to bed, and when i wake, i’m usually happily surprised to see them all done. occaisionally i’ll get one that appears to render the whole time, but upon playback it is nothing but a black screen…or sometimes green. . .
    what version are you using??
    thanks for helping out a bonehead!
    __________________________
    dual 2 GHz PowerPC Mac G5
    2GB MB DDR SDRAM
    GeForce FX 5200 graphics card
  • Evan Thomas phillips
    July 18, 2007 at 10:18 pm
    I’m using FCS2 (FCP6) on an Intel MacPro.
  • Mike Kahn
    July 18, 2007 at 10:22 pm
    I found that the best way to do a batch compression was to highlight all sequences you want to export within FCP and then go to file/export/compressor. This will put them all in compressor into the same “project” and you can either highlight all and select a setting or do a setting for each individually.
  • J. Tad newberry
    July 19, 2007 at 5:07 pm
    cool! sounds logical, i should’ve thought of that…
    thanks again!
    mh
