Activity Forums Compression Techniques Compressor & mulitplexed program streams
  • Compressor & mulitplexed program streams
    Posted by Chris Detjen on May 16, 2007 at 7:37 pm
    Curious if our company can create files for upload to DG FastChannel. We are limited to Apple’s suite of products (FinalCut Pro and Compressor).
    I am using Compressor v.2.3 and I see it has a preset for FastChannel. It creates an MPEG-2 transport stream with multiplexed audio. However, DG requires a program stream.
    Can Compressor create MPEG-2 program streams with multiplexed audio? Anyone use Compressor to create SD files for DG FastChannel?
    Thank you.
    Jen_studer replied 19 years, 1 month ago 5 Members · 6 Replies
  • Craig Seeman
    May 16, 2007 at 8:55 pm
    I’ve never seen a DG/FastChannel preset in Compressor but you can attempt one. You can always attempt building a custom preset and testing it with your DG/FastChannel Drop Box account. Compressor does create a transport, not a program stream.
    If you Compressor doesn’t do it though you’ll have to look into other options like Episode Pro which is what I use for DG/FastChannel but I think some people have had luck with Cleaner.
  • Chris Detjen
    May 16, 2007 at 9:12 pm
    You’re right. Compressor doesn’t have a preset. What I saw was a custom preset made by our editor. I am going to make a test file and upload it to DG FastChannel and see what their techs think. I’ll post any positive/negative results.
    Is there a basic difference between program and transport streams? I’m unfamiliar with the terminology.
  • Rich Rubasch
    May 16, 2007 at 11:47 pm
    You can use MPEGStreamclip to mux them together after compressor is done.
    squared5.com
    Rich Rubasch
    Tilt Media
  • Craig Seeman
    May 17, 2007 at 1:44 am
    And Compressor 3 will be able to create MPEG-2 Program Streams and my guess is we’re not more than 3 weeks from seeing that.
  • Zoner79
    July 17, 2007 at 10:02 pm
    Anyone have any luck using Compressor 3 for uploading to DG? I’ve made a template to their exact specs, but have failed every time. They say the length of the video is shorter than the slated 15 sec. But the video looks perfect on my end both visually and in length. Their only solution was to use a different encoder, like Episode. I’d hate to have to spend the extra money if Compressor seems to be working over here. I thought it could have something to do with the fact that I’m converting 23.97 material to 29.97. But I’ve set the timing parameters to match the original time. Could there be some other setting I’m missing?
    Anyone???
  • Jen_studer
    August 7, 2007 at 6:54 pm
    I don’t know about your timing issue, as we work in 29.97
    But I’ve been Dropbox certified using Compressor 3. We waited until we installed our studio upgrades before buying Episode or MC Coder. I’ve had DG telestream spots back to us to assure us that they look fine visually (as we had problems with Fast Channel’s ftp site in the past & interlacing issues).
    Compressor 3 does work though.
