Activity › Forums › Apple Final Cut Pro Legacy › Compressor MPEG-2
  • Compressor MPEG-2
    Posted by Outis on June 23, 2005 at 11:18 pm
    I posted on here as many of you are also experts with Compressor. I have footage that is 720×486 at 24p. So I am trying to make an MPEP2 at 24p in compressor. Trouble is, no matter what I do to the preset for the encoding, my file turns out to be 640×480 instead of 720×480 which is what it says it is in the summary for the MPEG2 preset. HELP?
    thank you
    David Bogie replied 21 years, 3 months ago 2 Members · 1 Reply
  • David Bogie
    June 24, 2005 at 2:24 pm
    That’s the hardwired default for MPEG2 in Apple’s world, can’t be changed AFAIK. If you need a different display, you crop it or letterbox it in FCP. Silly, but I think that’s all you can do. Check the specs in the Compressor online help for MPEG2, I’m pretty sure it’s all explained there.
    bogiesan
