Activity › Forums › Apple Final Cut Pro Legacy › Compressor / limiter in FCP 5
  • Compressor / limiter in FCP 5
    Posted by Mike on January 12, 2006 at 7:12 pm
    Has anyone actually used the limiter/compressor in FCP?
    I have tried, but it doesn’t seem to be doing anything. I have Pro Tools on
    another machine and I understand what I’m doing there, but I’m looking
    for a quick way to get compression when the quality doesn’t matter much.
    As I adjust the threshold and ratio, it seems like the it’s only affecting
    overall volume, as opposed to truly limiting.
    Jeff Carson replied 20 years, 8 months ago 5 Members · 5 Replies
  • Mark Maness
    January 12, 2006 at 7:34 pm
    Yeah…. its very awkward to use. You just need to keep playing with the settings until you find one that works. It sure would be nice to find a plugin that could do this very easily. Most of us aren’t audio experts. We just need to know that say -12db is our maximum level.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Ben Oliver
    January 12, 2006 at 8:01 pm
    i would even PAY for a plugin that wouldn’t allow audio to go over a certain level.
  • Thaxter Clavemarlton
    January 12, 2006 at 8:10 pm
    As a starting point, adjust the Settings to my “all 2’s” formula:
    Threshold (db) -20
    Ratio 2
    Attack Time 20
    Release Time 200
    Preserve Volume CHECKED (very important!)
    Now click the viewer to display the actual audio track and set the Level to “2” or “3.”
    Now, when you play the track it should be at a “more consistent” level.
    You can play with my “all 2’s” formula if you want, but its a good starting point for compressing the levels without a lot of compressor “pumping.”
    The “Threshold” setting will affect the clip the most… as you slide left, it brings more of the low levels UP.
    The actual volume adjustment now comes from the “Level” slider on the actual audio track (and you can key-frame that if you want.)
  • Ben Oliver
    January 12, 2006 at 8:13 pm
    i have a client that never wants audio delivered over -10db….would this work….im not much of an audio guy?
  • Jeff Carson
    January 12, 2006 at 10:09 pm
    Yep. This tried and true formula has been working here for almost everything as a starting point… Thanks Thax!
