Activity Forums Compression Techniques Compressor keeps failing
  • Compressor keeps failing
    Posted by Arturo Celleri on June 15, 2010 at 4:11 pm
    Good Morning,
    I am working with green screen video for the first time and sending my project to be compressed, using Quick Time H.264, Using Apple’s Compressor.
    The project was fully rendered and I’ve tried to compress it two times and it failed both times. I don’t know what’s wrong.
    I have had problems recently because my local HD is full and I’m currently creating more space. Maybe this was the problem?
    Anyways, I’m on a deadline and I would like to get any info I need to resolve this ASAP.
    My Sequence settings are: Frame size: 1440×810 (custom 16:9)
    Pixel Aspect Ratio: 1440 x 1080
    29.97 frame rate
    Compressor: Apple ProRes 422
    Any help is appreciated. Thanks,
    Arturo
    Arturo Celleri replied 16 years, 3 months ago 1 Member · 1 Reply
  • Arturo Celleri
    June 15, 2010 at 4:27 pm
    OK,
    I just read your recommendations for getting quicker support:
    Thank you,
    I am running Mac OS X 10.5.8
    I am using Final Cut Pro 6.06
    Compressor Version: 3.05
    My Computer is MAC Pro, with 2 x 2.8 GHz Quad-Core Intel Xeon
    Memory: 8 GB 800 Mhz DDR2-FB-DIMM
