Activity Forums Apple Final Cut Pro Legacy Compressor issues…ughh
  • Compressor issues…ughh
    Posted by Anthony Cook on February 8, 2011 at 8:45 pm
    Ok, before someone shoots me, I have read most of the threads about compressor HD to SD conversion, but I haven’t been able to see an answer which helps.
    I have 20 videos I need to convert down from 1080iHD to SD which total about 112 minutes of video to fit on a 8.5 GIG dual layer disc. I’ve tried the “DVD: Best Quality 120” AND “DVD: Best Quality 90”. My Bit Rates are 6.4 avg to 7.6 max / 2 pass…both settings look crappy, graphics look choppy around the edges and the aspect looks much smaller (I guess that’s 720). The self-contained QT files (same settings as timeline) that I’m sending to Compressor look great but are like 2 GIG each.
    The only difference in these two settings would be the bit rate, right? so if I jack the bit rate up on 120 minutes, there really isn’t a difference? Its not going to save more space? Is there a way to save space through cutting back on audio quality? Is the Bit Rate what affects the quality of the graphics?
    There has to be a setting I’m missing to get at least the graphics to look acceptable and fit 112 min on a dual layer disc…Its going to be on a LCD at a large trade show so I need it to look as good as SD can Possibly look! Thanks, Anthony
    Walter Soyka replied 15 years, 7 months ago 7 Members · 13 Replies
  • 13 Replies
  • Chris Tompkins
    February 8, 2011 at 10:11 pm
    Turn on your frame controls in Compressor.
    You can up the data rate but you can only fit so much on a disc, ya know?
    Up it some and see if you can still fit it all on the DL disc. If not, dial it back some.
    Frame control will help.
    you have 16X9 widescreen letterbox selected too right? This would be the correct aspect ratio settings.
    Chris Tompkins
    Video Atlanta LLC
  • Chris Brandt
    February 9, 2011 at 4:10 am
    What file format are you exporting to? For DVD I normally export to m2v and aiff, then convert the aiff to ac3 (reduces the audio file size by a great deal).
    Also, what are you sampling your created files on? The same system you’ll be screening them on? I’ve noticed that the DVD player and monitor system I used for playback can make a great deal of difference.
  • Tony Silanskas
    February 9, 2011 at 5:41 pm
    [Chris Tompkins] “Turn on your frame controls in Compressor.”
    Also, try the “Best” settings in frame controls. Helps a bunch with 1080 footage.
    tony
  • Kris Merkel
    February 9, 2011 at 5:44 pm
    There is no “one size fits all” when dealing with optimizing your footage for playback in any heavily compressed format.
    The “settings” are only starting points that need to be adjusted for your particular video elements. I agree with the previous poster that by turning on your frame controls and playing with the settings there is a great place to start.
    You are essentially resizing a 16×9 image to fit into a 4×3 frame and maintain the correct aspect ratio without losing to much quality.
    Take a small 10sec sample of your footage and keep tweaking the settings until you get something that looks ” pretty good”
  • Anthony Cook
    February 9, 2011 at 6:34 pm
    I’m going to M2v and Ac3. Yeah, I’m checking the M2v files on my mac pro with a Dell widescreen monitor. I’ve seen the output of these settings on HD tvs, computer screens, regular 4×3 TV sets, through DVD and Xbox players. Either Apple’s Compressor is a piece of crap or someone out there is holding out on how to get REAL quality HD to SD encodes. I mean, I’ve read a LOT of posts on it, tried tons of the suggestions and still haven’t been satisfied with any of the results.
    My file size is going from 2.05 GIG to 474.2 MB for the M2v…isn’t there a middle ground here? Any help or suggestions is greatly appreciated!!
    EXPORT FILE:
    1920×1080
    MPeg-2 video, linear PCM, time-code
    Color profile: HD (1-1-1)
    COMPRESSOR OUTPUT FILE:
    Settings: 90 min (after tweaking settings, says 70 min per layer)
    Mpeg-2, 720X480,
    Frame Controls On
    Motion Estimation: Best
    Re-size filter: Best (statistical prediction)
    Output Fields: Progressive
    De-interlace Filter: Best (Motion Compensated)
    Rate Conversion: Best
    Avg Bit Rate: 7.3, Max 8.6
    2pass VBR Best
  • Chris Tompkins
    February 9, 2011 at 6:48 pm
    Uhhh,…. you’re not deinterlacing are you?
    Chris Tompkins
    Video Atlanta LLC
  • Anthony Cook
    February 9, 2011 at 7:33 pm
    Hmm…I don’t really want to. I used a Flicker Filter/ deinterlace filter to get rid of the HD edge jaggies you see at 100% view during editing. I can’t find a way not to have compressor effect interlacing…here are the instances where I have to choose and maybe this is where I’m messing up:
    Video Format Tab: Field Dominance, choices are –
    Top first
    Bottom first
    Progressive
    and Automatic is greyed out
    Frame Control Tab:
    Output fields –
    Same as source
    Progressive
    So what do I choose to NOT Deinterlace? Thanks!
    Top first
    Bottom first
    Deinterlacing –
    Fast
    Better
    Best
    and I don’t know what reverse telecine means….
  • Chris Tompkins
    February 9, 2011 at 7:41 pm
    If you shot and edited progressive and output current settings
    make a progressive DVD
    compress to mpeg2 progressive.
    Chris Tompkins
    Video Atlanta LLC
  • Anthony Cook
    February 9, 2011 at 7:50 pm
    My sequence settings are “HDV – 1080i60” which says its upper field dominance and it says “Anamorphic 16:9: Off”…So I see that I should be choosing upper anytime it asks in compressor, but what do i set the Deinterlace option to under frame controls? Fast, Better, Best, or Reverse Telecine? I’ve tried best and its not great
  • Chris Tompkins
    February 9, 2011 at 8:01 pm
    OK, So stay Interlaced for you DVD. This is fine.
    In Compressor:
    Frame Control On
    Resize Filter – Best
    Output Fields – Same as Source
    Deinterlace – Best
    Rate Conversion – Best
    Let us know how this looks for you.
    Also, Format Tab:
    Chris Tompkins
    Video Atlanta LLC
