Activity Forums Compression Techniques Compressor Issues??
  • Compressor Issues??
    Posted by Thompson Coles on April 16, 2009 at 5:29 pm
    Ok I’ll try and make this as short as i can. Compressor isn’t allowing me compress anything. I am getting an error that says i should re-start and see if it installed correctly. So i do and no change. as a result i pulled FCP Studio off of my system completely and re-installed the entire thing, then added the updates. still no response. Was there a bug in the last update to FCP Studio that broke it? I have NEVER had a problem with compressor, and it ws working last friday. The only thing that happened is a kona issue where i had to uninstall and re-install the kona 3 software.. Ideas
    Dual core machine with 8GB ram
    Thompson Coles replied 17 years, 5 months ago 1 Member · 1 Reply
  • Thompson Coles
    April 16, 2009 at 5:43 pm
    I ran Disc Warrior and some other voodoo, and it appears to be fixed. Thanks anyway, i just wish I knew what caused the problem so i could address it directly if it happens again.
