Activity Forums Apple Final Cut Pro Legacy compressor issue
  • compressor issue
    Posted by Rich Rumppe on September 6, 2007 at 3:23 am
    I’ve searched past posts, but this appears to be something new
    I recently updated my operating system to 10.4.10. Running a G5 with PPC
    This it the first time I’ve tied to use compressor since.
    I’m using final cut 5.1.? The newest crossover version (intel & PPC) before the new FCP 6.
    I created a timeline in a project like always, with no issues. Then tried to FILE, EXPORT, USING COMPRESSOR.
    Here’s the problem. The USING COMPRESSOR is greyed out, its not an option.
    I can select make a quicktime movie or export using quicktime conversion.
    If this is a problem with the interaction between 10.4.10, then is there a solution that would let me create a quicktime and import it into I-DVD or something? Maybe I’m just one button away.( which is probably the more likely answer)
    Any suggestions would be appreciated.
    Rich
    Dogstalktome replied 19 years ago 2 Members · 2 Replies
  • Dogstalktome
    September 11, 2007 at 10:34 pm
    Unfortunately, this isn’t a solution. I’m just having the same problem and was wondering if you found a fix yet.
    Brian
  • Dogstalktome
    September 12, 2007 at 12:45 am
    Ok so now I have a solution!
    It’s right here, takes like 15 minutes to do.
    I had to do the remove and reinstall compressor. When I started going down the list some of the files weren’t even on my computer. I just ignored them and continued on.
    https://docs.info.apple.com/article.html?artnum=302845
    Now my compressor works.
