Activity Forums Apple Final Cut Pro Legacy compressor is stuck
  • compressor is stuck
    Posted by Jeffrey Durkin on August 21, 2009 at 8:00 pm
    Hello guys,
    I have a question reguarding compressor 3.0. For the last week I have not been
    able to process any clips because I have a job that appears to be stuck in limbo in the batch monitor.
    I kicked the job off a month ago, and it won’t cancel. I’ve tried restarting and all the usual
    fixes short of uninstalling compressor. Does anyone know about this problem?
    Jeff
    John Fishback replied 17 years, 1 month ago 4 Members · 3 Replies
  • David Roth weiss
    August 21, 2009 at 8:08 pm
    This has been mentioned by others and you should search the forum to see if the others found the definitive answer.
    Meanwhile, did you install from scratch, or update over the top of FCS2?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Michael Black fcp
    August 21, 2009 at 8:10 pm
    If you scroll down a bit, you’ll see I had this same problem the other day. I used that Compressor Repair app and it worked fine. Not so well since my update to FCS3, but gets the job done.
  • John Fishback
    August 21, 2009 at 8:59 pm
    Checkout https://forums.creativecow.net/thread/8/1006452#1006452
    https://www.digitalrebellion.com/compressor_repair.htm
    https://support.apple.com/kb/TS1888?viewlocale=en_US
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
