Activity › Forums › DVD Authoring › Compressor is Slow
  • Compressor is Slow
    Posted by Jeff on July 21, 2006 at 12:58 pm
    Anyone know if I’m doing something wrong to make Compressor 2.0.1 take 2.5 hours to compress an 11 minute sequence for DVD? When I get to the full 2 hour film this is going to be a mess. Here are the specs:
    1280 X 720 DVCProHD Varicam footage output as Quicktime at full resolution from Final Cut
    11 minutes in length
    Compressor 2.0.1
    Using the video setting: DVD Best Quality 90 mins 16:9 MPEG-2 6.2Mbps 2-pass 16:9
    Using the audio setting: AAC 128 kbps
    OSX 10.4.6
    5.5 GB Ram
    Am I missing something or is this standard. Or is there a better way to do this? How do the rest of you make DVD’s of long format projects?
    Thanks.
    Jeff
    David Roth weiss replied 20 years, 2 months ago 3 Members · 4 Replies
  • Noah Kadner
    July 21, 2006 at 2:11 pm
    I’d convert to Standard Def in FCP first. Compressor is incredibly slow on downconverts. Drop the HD footage into a 16:9 anamorphic NTSC sequence with the 8-bit uncompressed codec and export. Then drop into Compressor. Also depends on your processor speed. If you have above a DP 2 Ghz G5 you should be ok.
    Noah
  • Jeff
    July 21, 2006 at 7:42 pm
    It does make sense that Compressor is having a tough time with the HD footage.
    Downconverting in FinalCut is a good idea, but just taking the time (and disk space) to render the new SD sequence makes it less than ideal too. Looks like we’re going to get around this problem with either a real time DVD recorder deck or old fashioned VHS’s for client review. Anything else takes away too much editing time.
    Thanks much for the response.
    Jeff
  • Noah Kadner
    July 24, 2006 at 6:40 pm
    Or have a second machine just for DVDs. It’s the only way I ever get things done.
    Noah
  • David Roth weiss
    July 25, 2006 at 6:49 am
    Jeff,
    If you crossgarde to FCP 5.1 and then install the 5.1.1 update that will help. Lost of things in Compressor have been fixed.
    DRW
