Activity Forums Apple Final Cut Pro Legacy Compressor in FCP7 problem
  • Compressor in FCP7 problem
    Posted by Craig Richard on February 4, 2010 at 2:20 pm
    Does anyone else have output problems with Compressor in 7? 10.6.2, FCP7.01,outputting from the timeline with all the standard name changes to keep things smooth; I get a 1 frame flashing dialogue box that’s too quick on screen to actually read. It flashes every 10 seconds graying out all other compressor windows, and looks like it
    has the yellow ‘same name’ warning on it for identical names – however, that can’t be the issue since the names have been changed.
    It still outputs, but is slower, and I’m hoping of the same quality. All ideas welcome and thanks.
    Peter Witrak replied 15 years, 2 months ago 3 Members · 4 Replies
  • Mark Maness
    February 4, 2010 at 2:28 pm
    Well, Craig…
    This is one of those issues that we have been fighting with for a very long time with Apple. It seems that Apple is just blowing us off because they feel this is a non-essential operation within FCP to warrant a fix.
    The only work around is to export your program as a reference file or a complete Quicktime file and then use Compressor to compress to whatever format you want. It always works this way. But outputting from the timeline has never worked for me and for many out here on the COW.
    Another idea for you… Delete the prefs for Compressor. They can get all screwed up just like in FCP. I would suggest that you look at Digital Rebellion’s FCS Maintenance Pack. It does an awesome job of doing these things for you at a reasonable price.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Craig Richard
    February 4, 2010 at 2:35 pm
    Thanks Wayne, I’ll try it. I can’t decide whether it’s a snow leopard, compressor, or FCP issue, very annoying.
    C
  • Craig Richard
    February 11, 2010 at 11:04 pm
    After an exhaustive investigation, and no help from Apple, it turns out compressor was trying to make network connections thru my firewall. Firewall off for the output, no problems.
    CS
  • Peter Witrak
    July 12, 2011 at 12:12 am
    Thanks for this! Had the same issue.
