Activity Forums Apple Final Cut Pro Legacy Compressor help – making the right droplet(s) for HDV source
  • Compressor help – making the right droplet(s) for HDV source
    Posted by J. Tad newberry on March 26, 2010 at 1:48 am
    I’m having a bugger of a time trying to figure out which droplet setting to use to make small, low-res files for client approvals. For this one, starting with an HDV project (sometimes first converting all footage to DVCPro HD or XDCam codec before editing), i render out a single QT, but i’m not finding a Compressor setting that fits the 1440 x 1980 aspect ratio…usually rendering a “too tall” 4×3 file. What droplet would work the best, and/or how do you alter the settings before making a droplet? The Compressor settings i’ve been trying are ghosted and can’t be changed (i.e., MPEG-4, H.264, etc.)
    Thanks again!
    J. Tad Newberry
    Big Ya Productions
    Mac Pro 2.66 GHz Quad-Core
    3 GB RAM
    http://www.bigya.tv
    Bret Williams replied 16 years, 5 months ago 2 Members · 2 Replies
  • J. Tad newberry
    March 26, 2010 at 2:42 am
    duh…
    Sorry once again for clogging up the works here . . . after i actually chose a setting INSDIE of Compressor, they become magically editable. On my way…
    Thanks again!
    J. Tad Newberry
    Big Ya Productions
    3 GB RAM
    http://www.bigya.tv
  • Bret Williams
    March 26, 2010 at 4:58 am
    For HD, I usually export QT conversion, h.264, max data rate 750mb/sec, auto keyframes, one pass for faster encode, 640×360, 32khz, 16bit, mono. Exports out faster than real time and looks good. Dissolves can break up at this data rate, but generally acceptable for web client approval.
    And since you’ve got an h.264, just change the .mov to .flv and you have a flash video file. It still needs to be wrapped in a .swf controller to have playback buttons and size controls.
