Activity › Forums › Compression Techniques › Compressor frame controls????
  • Compressor frame controls????
    Posted by Jamil Yamani on June 17, 2008 at 12:19 am
    Hi there
    I am using Compressor to turn out some mpeg2 files. however i am not working in standard pixel resolutions such as 720 x 576 etc. in the geometry settings in the inspector pallette the dimensions field is greyed out, this means i can’t set the output pixel dimensions!
    does anyone know how i can access these controls? any help would be very appreciated?
    thank you
    jamil
    Jamil Yamani replied 18 years, 3 months ago 2 Members · 2 Replies
  • Daniel Low
    June 17, 2008 at 7:00 am
    Check page 186 of the compressor 3 manual – it’s all explained clearly in there. If you are using compressor 2 just check out the MPEG-2 section.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Jamil Yamani
    June 17, 2008 at 7:29 am
    hi danny
    thanks for the info, i had looked that up previously i just thought there may have been a work around. encode view and main concept both offer control over the frame size. this is not an option in compressor if you are exporting to mpeg2.
    i wish that wasn’t the case as i am encoding for onlyview (multi screen, multi format etc etc) = unusual frame sizes
    best + thanks
    jamil
    The Electric Canvas
    Large Format Projection Specialists
    Sydney, Australia
