Activity Forums Apple Final Cut Pro Legacy Compressor frame controls
  • Compressor frame controls
    Posted by Bleakley Mcdowell on February 23, 2014 at 12:47 am
    I’m converting some SD 720×480 29.97 footage to HD 1440×1080 23.98 in Compressor.
    Under video settings on the “encoder” tab I’ve set a custom frame rate of 23.976, which I read on this forum was the best thing to do.
    So, on the “frame controls” tab under ‘set duration to’ I’m not sure what to choose.
    The default is “100.000% of source”, but I can also choose a variety of different frame rates or choose “so source frames play at 23.98 fps”
    What should I choose? Just leave it at the default of 100% of source?
    Bleakley Mcdowell replied 12 years, 7 months ago 2 Members · 2 Replies
  • Shane Ross
    February 23, 2014 at 2:53 am
    Leave it as 100% of source. You don’t want to speed it up, nor slow it down. But keep it the same duration.
    Shane
    Little Frog Post
  • Bleakley Mcdowell
    February 23, 2014 at 3:08 am
