Activity › Forums › Apple Final Cut Pro Legacy › Compressor for iphone
  • Compressor for iphone
    Posted by Jacques Hinkle on March 8, 2010 at 11:03 pm
    I’ve been trying all day and haven’t been able to figure out how to create video for the iphone that plays full screen when it’s zoomed out. Basically I don’t want to see black anywhere around the frame ever.
    is this an aspect ratio/cropping issue? Any input is great appreciated!!
    I’m using final cut studio 2
    Thanks!!
    Erik Lindahl replied 16 years, 6 months ago 4 Members · 4 Replies
  • John Fishback
    March 8, 2010 at 11:21 pm
    I don’t remember if FCS 2 had Compressor presets for the iPhone. FCS3 does. Here are the details of the preset:
    Name: H.264 for iPod video and iPhone 320×240 (QVGA)
    Description: H.264 video @ 600 kbps, progressive, multi-pass. Audio is 44.1kHz, stereo
    File Extension: m4v
    Estimated size: 257.93 MB/hour of source
    Device: iPod/iPhone QVGA
    Frame sync rate: 5 seconds
    Video Encoder
    Format: QT
    Width and Height: Automatic
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls: Automatically selected: Off
    Codec Type: H.264
    Multi-pass: On, frame reorder: Off
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 50
    Key frame interval: 120
    Temporal quality: 50
    Min. temporal quality: 50
    Average data rate: 0.6 (Mbps)
    Maximum data rate: 0.768 (Mbps)
    Audio Encoder
    Format: MPEG4
    Sample Rate: 44.100kHz
    Channels: 2
    Bits Per Sample: 16
    AAC encoder quality: high
    Data rate: 128 Kbps
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Jacques Hinkle
    March 8, 2010 at 11:41 pm
    Thanks for your reply! CS2 does have presets for the iphone. I tried changing them to what your response showed and when the view is zoomed out it still shows black on the top and bottom of the screen. Basically I can’t have black anywhere when zoomed out.
    I really appreciate your help John!
    Jacques
  • Michael Sacci
    March 9, 2010 at 12:03 am
    I think you are trying to defeat a feature that is built into the iPhone QT player.
    When playing back video the QT has 2 settings full view which gives you the true 16:9 image with the letterbox or zoomed in, which crops off the left and right to fill the tip and bottom without distortion. Cause the screen is neither 4:3 or 16:9. I’m probably telling you something you already know but for others.
    The iPhone screen is 480×320 so have you tried that? If that doesn’t help you maybe fighting against the software itself.
  • Erik Lindahl
    March 9, 2010 at 9:56 am
    Was going to add that the iPhone screen is 480-by-320-pixel, not 320×240.
    25 / 30 fps, 480×320 pixles at below 1.5Mbit/s will run on the iPhone with ease.
    As mentioned above, the iPhone-screen as a 1.5:1 aspect ratio, so either 1.78:1 (i.e. 16×9) nor 1.33:1 (i.e. 4×3). To accommodate this you will have to crop some of your base material.
    Erik Lindahl
    Freecloud Post Production Services
    http://www.freecloud.se
