Activity Forums Apple Final Cut Pro Legacy Compressor for BluRay – Quick Inquiry
  • Compressor for BluRay – Quick Inquiry
    Posted by William Edwards on September 29, 2011 at 4:55 pm
    So my client just asked for blu-ray files to be uploaded via FTP. The Compressor instructions were not very helpful.
    What I’m desiring is something that is compatible with the most systems for my 3 minute piece.
    1) Stream Usage: Blue-Ray or AVCHD? I’m guessing Blu-Ray
    2) Average Bit Rate: ‘Typical video bit rates with H264 might range from 7Mbps to 15Mbps, depending on your DVD bit budget’ So should I make it 15, with not know who will be creating the BluRay disc? Or the default 35?
    3) Max Bit Rate: Just leave it on the default 15?
    And finally, the audio, I’m thinking that the Dolby Digital Professional 2.0 default file in compressor will be just fine for that, correct?
    Thanks in advanced!
    William Edwards replied 14 years, 11 months ago 2 Members · 2 Replies
  • Chris Tompkins
    September 29, 2011 at 5:01 pm
    Just use the compressor pre-sets for Bluray and you’ll be fine.
    Go higher on the bit rate as your program is short and you do not have to try and fit a long program on a disc.
    Chris Tompkins
    Video Atlanta LLC
  • William Edwards
    September 29, 2011 at 5:24 pm
    Thanks Chris!
