Activity › Forums › Apple Final Cut Pro › Compressor, FCPX, and EVA1 footage
  • Compressor, FCPX, and EVA1 footage
    Posted by Oliver Peters on August 21, 2019 at 11:14 pm
    It appears that Panasonic EVA1 footage is not compatible with Compressor, even though I can open and use these files in FCPX (also Premiere, Media Composer, and Resolve). In Compressor the screen is just green or black. I would imagine there’s no fix for this, but if so, let me know. It’s odd that the two apps – supposedly using the same media framework – don’t support the same codecs.
    – Oliver
    Oliver Peters – oliverpeters.com
    Oliver Peters replied 7 years, 1 month ago 2 Members · 5 Replies
  • Eric Santiago
    August 22, 2019 at 12:14 am
    Did you update firmware on the EVA lately?
    My day job has two EVA1s I will check tomorrow.
    I believe they were updated a few months ago.
  • Eric Santiago
    August 22, 2019 at 12:15 am
    What version Compressor?
    I know the footage works fine in FCPX 10.4.3.
  • Oliver Peters
    August 22, 2019 at 12:50 am
    Don’t know on the updates for the camera. That’s the Dir/DP’s territory. He’s an outside client. I do have access to some other EVA1 footage from a different source and can double-check that tomorrow.
    Compressor is the most current version, whatever that number is.
    But, as I say, it’s fine with FCPX. FWIW – ProRes RAW is also treated differently in the two different apps.
    – Oliver
  • Oliver Peters
    August 22, 2019 at 11:44 am
    So this does appear to be a firmware issue with the camera. I tested some other EVA1 files from a different camera and Compressor is OK with those. One other difference is that the files in question are 4096 wide, while the “good” files are 3840. Not sure if that’s a factor or not.
    Compressor 4.4.4
    – Oliver
  • Oliver Peters
    August 22, 2019 at 2:52 pm
    Actually it may not be a firmware issue, but rather choice of codecs. The 3.0 firmware update enables a 10-bit 4:2:2 All-I AVC VBR recording at up to 400 Mbps. QuickTime X player won’t open these files either. The DP tells me he can’t open these in the free version of Resolve, only VLC. So it’s probably the 10-bit issue. The “good” EVA1 files I tested were 8-bit using one of the other codec options. So it’s still a curiosity that Compressor can’t open all of the same pro codecs that FCPX can open.
    – Oliver
