Activity Forums Compression Techniques Compressor fails with error -120
  • Compressor fails with error -120
    Posted by Tom Step on January 29, 2010 at 11:04 pm
    I’m making a stream file from a qt file (exported from fcp) and Compressor fails with Status: Failed: QuickTime error -120. File plays fine in QTPro and FCP. Tried to change output folders, no help. Made new custom setting from apple sets, still no go. Used a file that worked previously, now does not work… Any ideas?
    Also is there a depository of QT errors for FCS?
    Tom
    ^__^ A color grade for every project.
    Dorit Grunberger replied 15 years, 5 months ago 3 Members · 3 Replies
  • Dorit Grunberger
    February 8, 2011 at 7:27 pm
    Hi Tom
    Did you ever get an answer to this problem? I too out of the blue am getting error -120, even for projects that worked fine just the day before. It looks like anything I put through compressor is basically failing 🙁
    Thanks in advance,
    Dorit
  • Matthew Manzano
    March 31, 2011 at 4:56 pm
  • Dorit Grunberger
    March 31, 2011 at 6:23 pm
    I think I ultimately chucked the preferences and restarted the computer. It’s been a while so I don’t remember, but I’ll keep this info handy,
    Many thanks,
    Dorit
    Thanks in advance,
    Dorit
