Activity Forums Apple Final Cut Pro Legacy Compressor export off 1 frame in 23.98. but export works in fcp
  • Compressor export off 1 frame in 23.98. but export works in fcp
    Posted by Max Slomoff on August 6, 2012 at 4:01 am
    hello,
    i’m noticing an issue with compressor and 23.98 footage. when i transcode a prores file to a proxy the timecode changes by one frame. (duration is the same, but the start and end frames are 1 framed later than the original)
    any ideas how to fix this?
    thanks,
    max
    Olivier Aubut replied 13 years, 12 months ago 2 Members · 1 Reply
  • Olivier Aubut
    September 27, 2012 at 3:08 pm
    Hey
    I don’t have a solution, but I have the same problem.
    It seems to be a problem with compressor 4 because I never had this issue before upgrading from compressor 3.
    Olivier
