Activity Forums Apple Final Cut Pro Legacy Compressor errors from FCP 6.0.2
  • Compressor errors from FCP 6.0.2
    Posted by Kent Beeson on March 21, 2008 at 6:39 pm
    HI
    Been tyring to simply export a 13 sec menu from FCP 6.0.2 using Compressor 3. The timeline is ANIMATION, from Livetype graphic, with NONE as the field dominance in both the graphic and Seq settings…
    When I export to Compressor, I get an error message saying “File error: A file of this name already exists.”
    But it can’t have as I just made it and renamed it…then when Compressor opens it says, “Can’t preview movie, FCP is busy.” So I click OK, and drag my MPEG2 preset to the well up above, it accepts it, then I hit submit and Batch Monitor shows it failed (each time I do this) but I don’t know why…I have set Apple Qmaster to 4 for Selected service (on).
    K
    Kent Beeson replied 18 years, 1 month ago 1 Member · 1 Reply
  • Kent Beeson
    March 22, 2008 at 12:31 am
    This is what the report from Batch Monitor says:
    Status: Failed – Final Cut Pro generated an error or unexpectedly quit. User aborted Media Server.
    I have no idea what it’s saying as I’ve not aborted anything.
    K
