Activity Forums Apple Final Cut Pro Legacy Compressor equivalent to still/freeze duration
  • Compressor equivalent to still/freeze duration
    Posted by Morten Berg on April 16, 2013 at 2:41 pm
    I’m trying to get my head around this!!
    I need to use compressor to import a still sequence and export in ProRess proxy.
    I need each still picture to be “duplicated” 3 times, the equivalent to still/freeze duration in Final Cut or Quick Time 7..
    help!!! please
    Morten Berg replied 13 years, 5 months ago 2 Members · 2 Replies
  • Rafael Amador
    April 16, 2013 at 3:07 pm
    You haven’t chose the best application to manage Sill Sequences, but..I would try this way:
    – Set the “Frame Control ON.
    – In “Rate Conversion”, use “Fast: Nearest Frame” (that will make to repeat the stills without any blending).
    – Set Duration 300%.
    rafael
  • Morten Berg
    April 16, 2013 at 6:55 pm
    First try rendered a completely black video, will try again with other codec and settings.
