Activity Forums Apple Final Cut Pro Legacy compressor encoding progressive
  • compressor encoding progressive
    Posted by Jon Gagnon on February 4, 2010 at 2:53 pm
    Hello,
    Hope this doesn’t sound to newbie-ish.
    I’m editing footage that was shot on mini DV that is 30P. It was captured as regular dv ntsc then in the clip settings changed the fields option to NONE. When I export from that timeline it looks great. However when I send to compressor and select progressive it looks like crap, mixing the fields, ants marching look, etc…
    Any ideas would be swell…
    Rafael Amador replied 16 years, 7 months ago 2 Members · 3 Replies
  • Rafael Amador
    February 4, 2010 at 3:00 pm
    Hi Jon,
    Had you changed the Sequence to NONE too?
    rafael
    http://www.nagavideo.com
  • Jon Gagnon
    February 4, 2010 at 4:22 pm
    Yes
    NTSC – ccir 601
    no field dominance
    29.97
    animation codec (there’s a few graphics)
    I’ve also tried 8 bit uncompressed.
  • Rafael Amador
    February 4, 2010 at 4:32 pm
    Try exporting a self-contained movie. Change the sequence codec to Prores.Make sure that in the Options (Sequence Setting> Prores> Options Is not set for interlaced.
    rafael
