Activity › Forums › Compression Techniques › Compressor Encode Fails
  • Compressor Encode Fails
    Posted by James Dow on March 3, 2010 at 1:45 pm
    I have a sequence in FCP6 that I send to compressor for encoding to m2v for DVDSP….each time (3 trys) Compressor says that the encode has failed.due to a Quicktime error. First time this has happened to me. What do I check first?
    James
    JPD
    James Dow replied 16 years, 7 months ago 2 Members · 2 Replies
  • Daniel Low
    March 3, 2010 at 2:33 pm
    Instead of send to compressor, make absolutely sure everything is rendered in the sequence then export as a Quicktime Movie using Sequence settings.
    Sent from my iPad Nano.
  • James Dow
    March 3, 2010 at 2:43 pm
    I will try that…thanks, Daniel
    I copied and pasted the edit to a new sequence and sent to Compressor.
    It just finished, and says successful. Is it technically better to do it the way you suggested?
    JPD
