Compressor & Dual Core
Hi!
I have a question about Compressor 3.5. I’m working on a Macbook Pro 2 GHz Intel Core 2 Duo / 2 GB 1067 MHz and unfortunately it takes forever to compress videos that I edited in Final Cut Pro. I know this is a common problem, since I’ve been looking for a solution in other forums. However, I’m still hoping there is a way to increase the speed.
When I open the Activity Monitor, I can see that only one core is used, and I would like to know whether it’s possible to use both cores of my Macbook Pro, or if this is a no-go because you’re not supposed to use all your cores? I wouldn’t mind not being able to work on other things during compression.I read that you can activate the cores via Apple Qmaster, but I’m not sure if compressor only lets you do that if you have at least 4 cores? The thing is, when I open Qmaster in the system preferences and under services I click on “Compressor” and activate “Share”, the button “Options for selected devices” is gray, so I can’t click on it to add instances. I tried to access Qmaster directly in Compressor as well, but I couldn’t find anything. Here’s a screenshot:
Any help would be appreciated!
