Activity › Forums › Compression Techniques › Compressor Droplets
  • Compressor Droplets
    Posted by Chuck Purnell on March 11, 2009 at 4:38 pm
    Is there a reason why my Droplets that I created with FCStudio won’t work in FCS2? I tried to compress some footage for the web last night and when I dragged my file to the droplet, it did nothing. So I had to open Compressor and start from scratch with the settings which sucked!
    Is there a way I can access the settings I used to set up the Droplet? I did save the settings that I had to re-create but was wondering how I could see the settings that made up the droplet in case this happens again.
    Cre8tive Minds Entertainment, LLC
    Daniel Low replied 17 years, 6 months ago 2 Members · 1 Reply
  • Daniel Low
    March 13, 2009 at 11:31 am
    After you make the Droplet, look inside it (right click, Show Package Contents) and find the Settings folder in Resources. In there drag your setting file onto TextEdit.
    Fonts are like cologne:
    A bad choice speaks louder than a good one.
