Activity Forums Apple Final Cut Pro Legacy Compressor Droplets Won’t Work After Copying to Other System
  • Compressor Droplets Won’t Work After Copying to Other System
    Posted by Jimmy Spangler on January 13, 2009 at 2:42 am
    I am having trouble transferring Droplets from one system to the other. A lot of times I can get Droplets to transfer from system to system but certain times the Droplets will not transfer. I can not determine a reason why it would work sometimes and not others.
    Has anyone else had trouble doing this? I just wish I knew what to look for as a variable for this so I could avoid whatever is causing this problem.
    All of our systems are running Compressor 3 from Final Cut Studio 2. Some systems are PPC and some are Intel, but I haven’t noticed that being the issue.
    Any help would be greatly appreciated.
    thanks!
    Jeremy Garchow replied 17 years, 8 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    January 13, 2009 at 3:45 am
    Do you put custom destinations in the ones that don’t work?
    Jeremy
