Activity Forums Apple Final Cut Pro Legacy Compressor deinterlacing time — are newer versions faster?
  • Compressor deinterlacing time — are newer versions faster?
    Posted by Robert Withers on October 10, 2013 at 7:03 pm
    I’m working in FCP 5.5 in OS 10.5.8 on a project I started a few years ago on an older MBP, did a lot of cutting, and can’t XML export to my new MBP and Premiere Pro because the FCP project was all based on cutting subclips and the XML is garbage.
    So I plan to finish the project in FCP 5.5 on this machine, save as a Quicktime, then import to a PrPro HD project.
    That’s just the background. This project was shot in miniDV as NTSC 29.77 interlaced and ugly artifacts are showing up when I port it through firewire to an HDTV monitor.
    I did a test deinterlacing with Compressor 2, with some heavy processing, and it came out very nice. But the 2-minute test took about 4+ hours to process. The whole sequence will be at least 30 minutes, so that’s maybe 60 hours to deinterlace.
    Would it be better to install FCP 7 or X on my newer MBP, and use Compressor 4 to deinterlace either the FCP file or a straight Quicktime? Will it work to save the straight Quicktime in my FCP 5.5 and use Compressor 4 or other software to deinterlace on the new machine?
    Thanks for any thoughts.
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
    Robert Withers replied 12 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
