Activity Forums Compression Techniques compressor de-interlacing issue
  • compressor de-interlacing issue
    Posted by Hoss Sarbaz on July 10, 2009 at 6:04 pm
    I’m running FCP studio 2 (6.06 with Compresser 3) on a 4 x 2.5 Ghz Power G5with OSX 10.5.7.
    I am trying to compress a source file is 10 bit uncompressed Quicktime video file to h264 for web streaming.
    The problem is I can’t get a clean progressive output file. I’ve tried everything from using de-interlace plug ins in FCP which works fine but in compressor the image gets blurred.
    I tried dropping the raw 10bit file into compressor by passing FCP but still can’t de-interlace it.
    I turn on the frame control set my settings to progressive and drop down to best motion and such…but still comes out crappy resolution with interlacing issues.
    if anyone has a solution please advise. No I don’t want to get suggestions for buying plug ins or additional software, if thats your advice then please do not reply. I need a solution with out making purchases if there is one… thanks!
    Daniel Low replied 17 years, 2 months ago 2 Members · 1 Reply
  • Daniel Low
    July 13, 2009 at 9:16 am
    More details please on the source and the target formats, frame size, format of the source, target dimensions FPS etc etc etc
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
