Activity Forums Apple Final Cut Pro Legacy Compressor Crash When Importing QT Ref
  • Compressor Crash When Importing QT Ref
    Posted by Olaf Steel on March 24, 2015 at 7:26 pm
    I have a 90min Avid sequence which is all DNxHD 175x media which I’m exporting as a QT ref before bringing into Compressor with the hopes of making an MPEG-2 M2V file.
    Earlier today I tried a test compression using a QT ref of just 4-5 mins of my sequence. It worked flawlessly. Then I made a ref of my entire 90min sequence and tried to import that into Compressor. Compressor crashed with the following error message:
    “Compressor quit unexpectedly while using the AvidAVinCodec plugin.”
    I tried the original short 4-5min test ref file, and now Compressor crashes on that too – strange…
    Here’s what I’ve tried:
    – Reinstalling the Avid codecs
    – Reinstalling Avid
    – Various Compressor fixes within the Pro Maintenance Tools app – using the free trial version.
    I’ve scoured the web looking for help with this on forums, but only come up with a few instances of the same issue, but so far no one seems to have a fix for it – there must be one by now, right?
    I’m using OS X 10.8.5
    Thanks in advance for any help any of you can offer.
    Olaf Steel replied 11 years, 6 months ago 1 Member · 2 Replies
  • Olaf Steel
    March 24, 2015 at 7:35 pm
    UPDATE:
    I tried to bring that QT ref into FCP7 with the hope of exporting FCP’s version of a QT ref and then bring THAT into Compressor. FCP crashed with the same error message as Compressor: “Compressor quit unexpectedly while using the AvidAVinCodec plugin.”
    So it must be the Quicktime codec, but how do I fix it? I’ve already reinstalled the Quicktime codecs, as well as Avid.
    I’ve used these workflows many times in the past. Why am I getting crashes now all of a sudden – after not making any changes that I’m aware of.
  • Olaf Steel
    March 24, 2015 at 10:05 pm
    SOLVED!
    Turns out it was a corrupt slate I put on the start of the full sequence, but wasn’t included in the 4-5min test export.
    I replaced the slate and all seems to be working normally once more!
