Activity › Forums › Compression Techniques › Compressor Color Space
Posted by Jimmy Stewart on October 19, 2009 at 8:03 pmHi,
Im using compressor to make mpeg2 files for dvd. original material is xdcam that im downconverting. works fine when i bring into dvd studio pro. thing is, the white are blown out. i want to change the color space in compressor, but it is grayed out and wont let me change it from “default for encoder”
anyway thoughts on how to change this?
thanks,
j
Kay Brooks replied 13 years, 11 months ago 3 Members · 10 Replies -
Daniel Low
October 19, 2009 at 9:24 pmFrom https://www.apple.com/support/releasenotes/en/Compressor_3.0_rn/
“Color Tab in Inspector
The Filters pane of the Inspector now includes a Color tab for selecting and adjusting color space settings.This tab is available for the following QuickTime output file formats only:
H.264
Apple ProRes 422
Apple Intermediate Codec
JPEGTo select a color space setting, choose one of the following from the Output Color Space pop-up menu:
Default for Encoder: Compressor chooses the output color space based on the dimensions of the output file.
Preserve source: Retains the color space of the source media file.
SD (601): Forces the output file to the ITU-R BT.601 (standard definition) color space.
HD (709): Forces the output file to the ITU-R BT.709 (high definition) color space.__________________________________________________________________
“There’s no chance that the iPhone is going to get any significant market share. No chance.”Steve Ballmer To USA Today: 30 April 2007
“We and Apple are neck and neck and we’re chasing the two
other players,”Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
Jimmy Stewart
October 19, 2009 at 9:32 pmis it still possible to make an standard def dvd using jpeg or apple pro res codec?
thanks!
Daniel Low
October 19, 2009 at 9:48 pm[Jimmy Stewart] “is it still possible to make an standard def dvd using jpeg or apple pro res codec? “
No, and it never was. The DVD video standard requires MPEG-2.
Jimmy Stewart
October 19, 2009 at 9:55 pmso is there anyway to not have my whites blow out once its compressed to a mpeg 2?
Daniel Low
October 19, 2009 at 10:02 pmHow exactly have you evaluated that the whites are blown out?
Jimmy Stewart
October 19, 2009 at 10:04 pmon the dvd they are really hot. but it looks fine in final cut pro.
Daniel Low
October 19, 2009 at 10:19 pmSorry to repeat myself but, how exactly have you evaluated that the whites are blown out?
What scope or monitoring method are you using?
Jimmy Stewart
October 19, 2009 at 10:48 pma mac laptop and tv set. no scope. the whites are just blown out. no definition.
Daniel Low
October 19, 2009 at 11:10 pmOK,
Sorry but that’s not anywhere near exact. Your Mac laptop very likely uses a low quality (when compared to broadcast quality) TN panel and this is dithered from 6bit. “A TV set” could mean anything.
Sorry, I don’t want to appear as being difficult but you are probably not using the correct gear to reach a correct judgement on how your video really looks. (Have you even calibrated your laptop display? What Gamma setting are you using? etc).
That aside, if you need to colour correct, then you should do this in FCP or use the more basic filters in compressor which are somewhat hit and miss.
Kay Brooks
October 10, 2012 at 4:40 pmSimple answer to the problem:
You can adjust your color values to more your liking through ‘Filters’ tab in the ‘Inspector’ window. I’ve had the same problem with the whites being blown out (no scope needed – you can SEE it with your eye on any monitor). I’ve gotten the best results from adjusting the ‘Gamma’. But you can also use the common controls of ‘Brightness Contrast’. I’ve also tried the ‘BlackWhite’ Restore, and that’s pretty good if you want to get a ‘crushed’ black feel.
Hope this is more helpful!
