Activity › Forums › Apple Final Cut Pro Legacy › compressor changing TC reported to QT
  • compressor changing TC reported to QT
    Posted by Doug Beal on September 15, 2010 at 3:14 pm
    Captured ProRes 422 1080 23.98 Psf from HDCam in FCP 6.05 (HDCam is 23.98 Psf same tri level Gen to both HDCam and Kona3).
    TC reported in captured QT file is the same as HDCam TC (59:50:00)
    drop captured file into Compressor ask for H264 (settings based off source resolution and frame rate)
    resultant H264 shows TC as 59:46:10 The frame rate is fine Picture is fine audio is fine
    Talking about TC shown in QT player lower left corner not BITC
    I’ll try one with BITC later. this needs to go out the door.
    Anyone notice this before?
    Doug Beal replied 16 years ago 2 Members · 2 Replies
  • Rafael Amador
    September 15, 2010 at 3:48 pm
    QT Player, as has been demonstrated here many times, it has not accuracy at all.
    Check your TC in FC better.
    rafael
    http://www.nagavideo.com
  • Doug Beal
    September 15, 2010 at 5:55 pm
    Yes it’s correct in FCP and correct on the file FCP captured when viewed in QT Player
    It’s the h264 compression that is reporting the wrong TC
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
