Activity Forums Apple Final Cut Pro Legacy compressor changes 720×480 to 640×480 in mpeg 2 w/embedded audio…
  • compressor changes 720×480 to 640×480 in mpeg 2 w/embedded audio…
    Posted by E. Eric johnson iii on July 14, 2007 at 7:48 pm
    of course the client needs 720×480.
    when i look at the inspector, prior to submitting, it says in the summary that the file will be 720×480; however, after it’s done and it plays back in QT, it comes out as 640×480.
    is there something i’m missing? it’s driving me nuts.
    i’m using compressor 3 & in the inspector (geometry) the “dimensions (encoded pixels) option is grayed-out so it’s not available.
    thank you for your input,
    sleepless in seattle
    (a.k.a. eric)
    e. eric johnson iii
    eric@lillmonster.net
    LILL MONSTER MOTION PICTURES
    producer-director-camera
    now in principal photography – START 2 FINISH: What It Really Takes to Race A Bike
    E. Eric johnson iii replied 19 years, 2 months ago 3 Members · 10 Replies
  • 10 Replies
  • Tom Wolsky
    July 14, 2007 at 8:03 pm
    What does it actually say in QuickTime info for the clip? Just 640×480, nothing else?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • E. Eric johnson iii
    July 14, 2007 at 8:15 pm
    hi tom-
    thanks for the quick reply & here’s what the QT file is telling me…
    QT Movie Inspector:
    Source: /volumes/raid… etc.
    Format: MPEG2 Muxed, 640 x 480 pixels
    fps
    playing fps
    data…
    Normal Size 640 x 480 pixels
    Current Size: 640 x 480 pixels (Actual)
    e. eric johnson iii
  • Rick Diamond
    July 14, 2007 at 8:47 pm
    The 640×480 file is most likely the same size as the 720×480. It may have converted it to square pixels.
    Rick
    July 14, 2007 at 9:22 pm
    hi rick-
    that makes sense.
    pardon my ignorance, but how do i reset the pixels so i get back to 720×480? i don’t see an option for that in compressor.
    thank you,
    eric
    e. eric johnson iii
    July 14, 2007 at 11:01 pm
    —same deaql when i try it with episode… even when using their “resize” feature.
    hmmmm…
    e. eric johnson iii
  • Rick Diamond
    July 14, 2007 at 11:22 pm
    What settings in compressor did you use to create the file?
    July 14, 2007 at 11:51 pm
    hi rick-
    i started with the basic “DVD-Best-90minutes…” then i tweaked what settings i needed too, i.e. added “audio layer 2” changed the settings my client needs, “upper-field first” and that’s about it.
    i got the audio, but the 720 is a mystery.
    i also tried it in sorenson, but they don’t support mpeg2 muxed… so…
    that’s where i stand.
    thanks for your help.
    eric
    e. eric johnson iii
    July 15, 2007 at 1:38 am
    sorry for the additional post (again)…
    i took one of the compressor made mpeg2/lyr2-audio files into streamclip and it tells me that the file size is 720×480; even tho’ it says it’s 640×480 in QT.
    am i insane or is there something in QT that automatically reads mpeg2 as 640?
    again, thanks for the help.
    eric
    e. eric johnson iii
  • Rick Diamond
    July 15, 2007 at 1:55 am
    It must be the way QT is interpreting the pixel aspect ratio. Sounds like you’re good to go.
    Rick
    July 15, 2007 at 4:31 pm
    thank you rick.
    i was wondering if that might be the deal. i couldn’t figure-out any other possible answer. getting some affirmation via the cow helps in the overall scheme of things.
    all the best & again, thank you.
    eric
    e. eric johnson iii
