Activity Forums Apple Final Cut Pro Legacy compressor causes kernel panics
  • compressor causes kernel panics
    Posted by Milton Hockman on February 8, 2008 at 9:06 pm
    im going nuts.
    im trying to use compressor to make mpeg2 files for DVDSP.
    No matter which way i do it, through FCP or alone with QT Ref files, after a little bit through in Compressor a kernel panic comes up.
    Was saying Corrupt Skip LIsts.
    I went back to 10.3 thinking it could be 10.4 problem. I also zapped PRAM. I also reinstalled COmpressor and FCP.
    NOw Says Corrupt Stacks.
    I can export other types of files – mpg4, quicktime movie, etc. No other program has problems. I use AE all the time and output quicktimes.
    Seems like it only causes problems when trying to make an mpg2.
    I also tried to use FCP to export mpg2 through quicktime conversion option. That cause kernel panic too.
    what is the deal?
    Motion Graphics Artist and Non-Linear Editor
    Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more.
    Milton Hockman replied 18 years, 6 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    February 9, 2008 at 4:54 pm
    Sounds to me like you need to perform a cleaner install… i.e. backup your data, and perform an erase and install of Tiger or later… update it all the way, then reinstall the studio over that nice new OS.
    As long as you don’t have a hardware problem, and it doesn’t sound like you do, it will fix you right up! Promise!
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Milton Hockman
    February 11, 2008 at 4:16 am
    ill try it out and let you know.
